voglio acquistare un sony expiria z in arabia saudita ,la garanzia vale in italia
Forse non sarebbe il caso di rischiare considerando che per i paesi dell'EEA (Europea Economic Area) insieme a Svizzera e Turchia viene suggerito di recarsi in un Centro Assistenza sule territorio di una di queste nazioni.
Probabilmente verrebbe tenuto conto della diversa area geografica.
http://www-support-downloads.sonymobile.com/common/warranty_phones_APAC_12.pdf
*Geographical scope of the warranty
If you have purchased your Product in a country member of
the European Economic Area (EEA) or in Switzerland or the
Republic of Turkey, and such Product was intended for sale in
the EEA or in Switzerland or in Turkey, you can have your
Product serviced in any EEA country or in Switzerland or in
Turkey, under the warranty conditions prevailing in the country
in which you require servicing, provided that an identical
Product is sold in such country by an authorised Sony
distributor. To find out if your Product is sold in the country
you are in, please call the local Sony Contact Center. Please
observe that certain services may not be available outside the
country of original purchase, for example, due to the fact that
your Product may have an interior or exterior which is different
from equivalent models sold in other countries. Please note in
addition that it may sometimes not be possible to repair SIMlocked Products.
Our goods come with guarantees that cannot be excluded
under the Australian Consumer Law. If you purchased your
product in Australia, you are entitled to a replacement or
refund for a major failure and compensation for any other
reasonably foreseeable loss or damage. You are also entitled
to have the goods repaired or replaced if the goods fail to be
of acceptable quality and the failure does not amount to a
major failure. For warranty service in Australia, please contact
1300 650 050 or Sony Service Centre, 189 Woodville Road
Villawood NSW 2163.
** In some countries/regions additional information (such as
a valid warranty card) may be requested.
Villawood NSW 2163.
