Hi Sony,
As the title suggests....
I've switched off power at the wall and restarted the TV but no difference. The youtube logo comes up and just hangs there.
Any ideas what I can do?
Regards, Jim.
Hi, I have the 32WD756 and was having the same problem. Having spoken to Sony UK Support earlier today, YouTube is now working. Here is a link to my thread which gives the solution :- https://community.sony.co.uk/t5/other-tvs/sony-32wd756-youtube-app-suddenly-stopped-working/m-p/2510...
Hope this helps
Hope this helps
Brill, that worked perfectly, thank you.
