YouTube HDR content is finally available!
You will find a playlist here. However, these clips will be played as SDR on Sonys for now.
With youtube-dl you can find vp9.2 encodings for those clips:
330 webm 256x144 144p60 156k , vp9.2, 60fps, video only, 2.38MiB 331 webm 426x240 240p60 256k , vp9.2, 60fps, video only, 3.87MiB 332 webm 640x360 360p60 485k , vp9.2, 60fps, video only, 7.35MiB 333 webm 854x480 480p60 909k , vp9.2, 60fps, video only, 13.83MiB 334 webm 1280x720 720p60 1991k , vp9.2, 60fps, video only, 28.18MiB 335 webm 1920x1080 1080p60 3201k , vp9.2, 60fps, video only, 49.70MiB 336 webm 2560x1440 1440p60 11166k , vp9.2, 60fps, video only, 170.23MiB 337 webm 3840x2160 2160p60 20122k , vp9.2, 60fps, video only, 335.45MiB
Those are webm however which the native Video app won't play.
We will see whether we will get support for it soon, even for the early 2016 models with the old MediaTek SoC from last year. At least Sony promised that back at CES:
Hi Kuschelmonschter,
Thanks a lot for the news.
Apologies that this initial post had been removed by the automatic spam filter.
I've restored it now from spam quarantine.
Thanks for that! It was probably considered a double-posting. The only purpose is to have some things discussed with the British community also.
Thanks for the info.
"However, these clips will be played as SDR on Sonys for now."
Upon switching HDR on manually, it seems to playback in HDR - or is it my eyes playing tricks on me?
You mean the TV profile? Or the respective stream in YouTube? Can you actually chose the HDR stream? Does the HDR profile activate for any source? I will also have to investigate deeper in the evening.
Just switching to the respective HDR profile on TV won't give you the YouTube HDR stream I suppose.
No, HDR does not activate automatically - but the option enables itself in the Picture Mode - So its detecting HDR at some point, as if there is no HDR detected - the HDR Profile in Picture Mode is not there. So manually changing the profile to HDR seems to work.
Which TV do you use for testing?
KD-55XD8577 is my model. So still on Android 5.1.
OK, so a model from the spring 2016 line-up with last year's MT5890 chipset. I will post my findings in the evening when I get back home.
Correct
