I'm getting distortion on this TV which only occurs when watching YouTube, Netflix or any similar source.
It does not happen watching Virgin Media or bluray.
The picture occasionally splits in 2 and/or distortion appears at the bottom of the screen.
Either a black bar at the bottom of the screen with a little of the image underneath, or a stripe of distorted colours at the bottom of the screen.
Hi there,
Please see the following troubleshooter for help with picture issues here.
Best wishes,
Sean
Thanks Sean
I rang Sony Support and did a system update.
All has been fine since.
Paul
Hi Blumine1818,
Glad to hear you got the issue resolved. I will let Sean know.
Regards,
Darran
Hi
Ironically the problem has returned this evening!
