hi there,
I have a KD-43XF7596. When I use the built in youtube app and search for 4K content, I notice once the video is streaming it just says its HD. If I click stats for the nerds, the resolution isnt 4k either. additionally, the resolution drop down box does not list 4k as an option
If I go on my PS4 PRO and then go to Youtube, I can watch 4k content just fine so it seems to be the integrated app that comes with the TV. FYI my TV has the latest software update etc.
Does anyone have any ideas on how I can get the app to start outputting 4K?
Many thanks
Melinda
Hi, I’m still having trouble, how do you update the app? Thanks Melinda
Via Google Play Store. It should update automatically. I disabled auto updates though. So I installed the update manually. You can check via Settings > Apps > YouTube which version is installed on your TV.
Thanks boss this worked for me. Would be cool to see an update button on actual app in the future. Makes me wonder what my other apps are in need of an update
the same to me (just got fx90). Youtube, browser and other programs only 1080p..... it's ugly, I see pixels from 1.5 meter away, my gaming monitor view is better. Movies would take only 5% of tv usage. Browsing, reading news on 1080P? And even Ada64 says, that display for programs is registered only as 1080p. 1080P is terrible!!!!!!!!!!!!!
Newest applicaton updated version, updated Youtube. Youtobe "options for nerds" show, that viewport is 1080p!!!!!!!
Check "options for nerds". If you can ran youtube on 4k, it means, that the stream from internet is in 4k "format". Check what is the "viewport", because it still could be converted and displayed as 1080p as in my case.
The slow CPU/GPU in Sony ATV1 and ATV2 are not capable of rendering a 4K GUI at a reasonable speed. So it is rendered in 1080p which then gets upscaled to 4K. Video is a totally different story. It is decoded and rendered via MediaCodec Surface directly to the 4K output without any intermediary downscaling. So all is fine. Judge by your eyes, not by numbers.
I have a 4k sony player the 800 model, and its internal apps have you tube and when i play from there i see full 4k
interesting enough my player is connected via wifi and can do it but tv directly connected can not. Whats up with this?.
Hi Rikdrt1, what's the model number of the TV? And did you try adjusting the resolution from the app itself?
