As the subject states, i have 2.5gb of available storage, but when i try and update any apps the tv is telling me I don't have enough space.
i have tried clearing cache and even removing some apps, but nothing is working.
Any ideas?
Update: i did a full reset on the TV and that has sorted the issue, i would love to know the cause just in case it happens again though
Thanks for the reply, as i mentioned in my first post. The storage information was telling me that i have 2.5gb available, thats over half of the total space on the TV.
I cant believe that a normal situation would be that it would need more than half the space to update one app on the tv.
i understand that, one of the apps as an example was the Now TV app which on my TV's is between 40-60mb in size (including cache)
This wouldnt update and gave the not enough space message
So its not as though it was some huge app, so its seems more than just a simple compressed v uncompressed data size issue
