I have a XH9505 connected to a STR-DH790 by hdmi cable using ARC. I have sound field (mode) sync on for both devices. Should the sound field (mode) change automatically depending upon the programme content? I can change the sound mode manually on the tv and the 790 changes to suit. No matter what is being viewed on the tv the sound mode must be changed manually. Is this correct or am I missing something?
It should change depending on the picture screen you select if there is a corresponding sound set on th HT. On my own A1 connected to an HTCT350 if I select Home cinema on the tv it switch on movie on the soundbar and if I select Sport the same on the soundbar
