- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xh 8196 locks motionflow
Is there any way to adjust motionflow on non native sony apps? I can only adjust it on native media player, netflix and watching tv. In any other apps it says that is unavailable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's not possible unfortunately.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
MOtionflow is only modifiable in Sony Native media player, Netflix and Tv watching. In any other apps it says not available and it is adjusted in the default setting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi mtampou , as Peter said, the option to adjust different settings varies on installed apps and might not be available. As a workaround, try adjusting the desired setting from the Home menu settings before getting into the app.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How can i adjust the settings from the home menu? If i click home and then adjust the picture it enables automatically TV viewing. And if i click the button to adjust it , on Applications section motionflow is locked (before entering in any application). So is there anything more i can do ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey, do you mean it's locked on the settings menu as well? What's the model number that you own? I will look it up for you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it is KD-43XH8196
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@mtampou does this happen on the latest software version as well?
Have you tried pressing the Option/Action Menu button while you're watching something (i.e. quick settings)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes Joe.
It does this even on the latest firmware upgrade. I tried set motionflow when the application is open but it is locked on normal, and does not change to custom or any other else value.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does this happen on specific apps or any/all of the downloaded ones you have?
