Hi does anyone know when sony will fix the info bar coming up on and off when playing a blueray/dvd disc on a player (X800M2). Gets very annoying. Been watching Lee Evans at o2 and info bar keeps coming on and off as we watch Lee... Been happening for a while now..
Have you tried disabling the info banner (under Watching TV in the settings)?
I have looked and option not there.. I have looked in multiple areas and can't see that option anywhere.. Are they fixing the issue..
Sony has confirmed that it's a known issue and that a fix is coming, but as a workaround I thought disabling it altogether would work.
Do you happen to have the player connected through an amp or soundbar?
A Soundbar (xf9000) so I can run atmos and dts x as tv doesn't allow atmos or dts x through..
i can wait till update
Have you tried connecting the player directly to the TV and not through the soundbar?
No not tried but if I do that I don't get atmos.. So what's the point. Plus dts x won't work either if go through TV. Will wait till update. 😊
