Hi all,
I have an X90J in Europe which is due a firmware update since last November according to Sony's website. However, when I check, the TV insists that I have the latest version. Is there anything I can do other than upgrading via USB? I would rather let the TV do it by itself, not to mention that both my USB ports are in use as a recording device and Android expansion.
Thanks!
Thank you for your reply. Is it normal for an update to still be rolling out after 4-6 weeks? If yes, then I will wait. If not, then perhaps something is broken and I need to contact support.
Hi @llima27
My A95K updates on-line almost immediately after a software release but my X89J did require me to update via USB after I tried on-line update several times without success.
Thanks @LightFoot.
My experience so far has been of immediate updates as well, but not this time. I'll see what happens in the next week or so. I'm trying to deal with a problem with the soundbar and want to make sure I have the latest firmware on the TV, even though the soundbar problem started out of the blue without any firmware changes.
I don't know the exaclty timing for rhe updates but it's normal for a 2022 device find the update before an 2021 device...
4/6 weeks can be normal...
