Hi there
Is it possible to plug a USB webcam into the x85c television, to use Skype? If so, what webcams are supported?
Thanks
The only product still listed is this CMUBR200(even if it doesn't say explicitely that is compatible with 2015 lineup) http://infoprodotti.sony.it/contents/instance1/files/document/2387TV12.pdf (I'm sorry it's in italian)
