Hi there. Will the x85c Television come with the one-flick remote? If not, where can I buy one, and is it really needed?
Thanks
Again in Italy specification it's included (RMF-TX100 touchpad remote) http://infoprodotti.sony.it/contents/instance1/files/document/2887KDX8505C.pdf
It's important for example in order to use i.e google voice search since it has an inbuild microphone
