- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Wont connect via LAN
Doesnt connect when I choose Lan line. Only connects with WIFI?
Waht can I do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @meekman1 and welcome to the Commmunity
Which model TV do you have?
Other members that have had connection troubles have either performed
factory resets and or have rebooted their routers which has solved the problem.
It's probably worth you trying these options first.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have a SONY KD65XE8596. I have re booted the tv 3 times but didnt work.
Im with sky tv and broadband fibre. the last tv connected no problem and this was just a case of taking one tv down and replacing. It connects using the wifi OK.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi again @meekman1
I think the best advice is to give Support a ring on +44 (0) 2073652810
At least you can tell them you have tried TV resets (and I assume the router too) to no avail, which may speed up the help
process a bit.
