Hi
My tv keeps saying my Google play music has stopped working, or my google play games has stopped working, or my google play store has stopped working. HELP!
Thanks Howard
@howarda15 wrote:Hi
Thanks Howard
Hi @howarda15. If I was you I would start with a soft reset (hold down the power button on your remote until it performs a soft reboot).
@howarda15 wrote:Hi
Thanks Howard
Thanks very much, it has worked so far
Howarda15
