Wireless headphones
profile.country.GB.title
stdenni55
New
Wireless headphones
Hi
I have a Sony tv model number KD55XD9305 and have just purchased a pair of Sony wireless headphones model number WH-CH510
Will they work with this television
Thanks
2 REPLIES 2
profile.country.IT.title
rooobb
Expert
Because your tv do not support bluetooth audio device. ( it should have an a2dp profile  that was not available at that time even for high end android tv)
I have the same TV, but new Sony wireless earbuds, so i was looking for the same info. What i found is that this TV does not support A2DP Bluetooth profile (for audio Bluetooth devices); so by itself you can not connect ANY bluetooth headphones, earbuds or bluetooth speaker. It seems that this can be solved by aquiring an external Bluetooth adapter, but please do your own research. (I haven't (yet) bought one or tested it. First i will update the TV to see if there's anything in the latest update...)
