Hi hope someone can help. I have a kdl40bx400 and trying to re tune in my new house. When I get to the connection part it says antenna or cable, I choose antenna and just stays on that screen . If I go on cable it runs a search but I don't have cable so won't pick up channels. I've tried a different tv and that's fine. Can anyone help.
Hi Gifton,
Have you tried to confirm a second time by pressing the OK button?
Hi @Gifton
Are you sure the antenna is connected securely to the TV? Are you sure the antenna works at all?
If the answer is yes, try resetting the TV: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs/kdl-42w653a/articles/00170...
Win_88
