Should my KD-49XD7005 TV. have come with a voice control on the remote? It seems pretty pointless having a voice enabled TV not supplied with a remote that complements it?
Since XD70 is an entry 4K model the voice remote is only available as an optional accessory.
The name of the voice control remote is RMF-TX200B.
Is my KD-49X8309C also an entry level TV? If so what is the RRP for the RMF-TX200B in the UK?
