We have purchased an android model (49x8305) and we are happily streaming HD videos from our NAS with VLC player, but cannot find a way to fast forward. Is anyone else having this issue?
The videos are .ts format from a HUMAX, though I exp ct it is not a video format specific issue.
Thanks for the feedback. I had not set the ff in configuration to get buttons on screen, but now have.
My OP stated it was not file type specific, but I now suspect it is.
Pretty much all our recordings are from a HUMAX Freesat+ with Raydons custom firmware, and are stored as .ts format on a Synology DS212j, many in unlocked HD format. I cannot ff any .ts file, using either the buttons on the remote or the screen. Nor can I jump to specific times.
i have looked at am MP4 file, and that does everything I would expect, ff OK from remote and on screen.
I guess this is a limitation we can live with.
