Audio level on sony tv bluetooth output to my sony headphones very low (indicated setting 98) compared to output level from headphone socket (indicated setting 22) I have varied out factory resets on tv and headphones numerous times
Sony authorised engineer called. He was unable to improve on the low Bluetooth volume issue. Also, he suggested I visit retailer and check Bluetooth headphone output on other Sony tv sets which I did. Even on the latest Sony models the low Bluetooth headphone output is low, the retailer needed the volume setting to be 76. So it seems that this is a Sony issue that has been present on Sony sets for ages.
@JohnR3 I think you need to contact Sony Support with these details and take it from there!
Thanks for suggestion
