cancel
Showing results for
Search instead for
Did you mean:
Update v5.381 Android 7 Nougat voor de modellen 2015/2016
SOLVED
profile.country.NL.title
pa3eia
Expert
Eindelijk de update naar Android 7 Nougat online
Deze pagina is alleen toepasselijk voor de X94C, X93C, X91C, X90C, X85C, S85C, X80C, S80C, W85C, W80...
Download beschikbaar op de ondersteuningspagina van je toestel.
suc6 ermee,
73's
I don't know everything, just trying to help you!!!
Thanks about the Kudos!!!
1 ACCEPTED SOLUTION
Accepted Solutions
pa3eia
Expert
Deze informatie geldt voor de volgende tv-modellen:
  • KD-75XD9405
  • KD-65XD9305
  • KD-55XD9305
  • KD-85XD8505
  • KD-75XD8505
  • KD-65XD8505
  • KD-65XD8577
  • KD-65XD8599
  • KD-55XD8505
  • KD-55XD8577
  • KD-55XD8588
  • KD-55XD8599
  • KD-65SD8505
  • KD-55SD8505
  • KD-75X9405C
  • KD-65X9305C
  • KD-55X9305C
  • KD-75X9105C
  • KD-65X9005C
  • KD-55X9005C
  • KD-75X8501C
  • KD-75X8505C
  • KD-65X8501C
  • KD-65X8505C
  • KD-65X8507C
  • KD-65X8508C
  • KD-65X8509C
  • KD-55X8501C
  • KD-55X8505C
  • KD-55X8507C
  • KD-55X8508C
  • KD-55X8509C
  • KD-49X8301C
  • KD-49X8305C
  • KD-49X8307C
  • KD-49X8308C
  • KD-49X8309C
  • KD-43X8301C
  • KD-43X8305C
  • KD-43X8307C
  • KD-43X8308C
  • KD-43X8309C
  • KD-55X8005C
  • KD-49X8005C
  • KD-65S8505C
  • KD-55S8505C
  • KD-65S8005C
  • KD-55S8005C
suc6 ermee,
73's
22 REPLIES 22
pa3eia
Expert
  • KD-75XD9405
  • KD-65XD9305
  • KD-55XD9305
  • KD-85XD8505
  • KD-75XD8505
  • KD-65XD8505
  • KD-65XD8577
  • KD-65XD8599
  • KD-55XD8505
  • KD-55XD8577
  • KD-55XD8588
  • KD-55XD8599
  • KD-65SD8505
  • KD-55SD8505
  • KD-75X9405C
  • KD-65X9305C
  • KD-55X9305C
  • KD-75X9105C
  • KD-65X9005C
  • KD-55X9005C
  • KD-75X8501C
  • KD-75X8505C
  • KD-65X8501C
  • KD-65X8505C
  • KD-65X8507C
  • KD-65X8508C
  • KD-65X8509C
  • KD-55X8501C
  • KD-55X8505C
  • KD-55X8507C
  • KD-55X8508C
  • KD-55X8509C
  • KD-49X8301C
  • KD-49X8305C
  • KD-49X8307C
  • KD-49X8308C
  • KD-49X8309C
  • KD-43X8301C
  • KD-43X8305C
  • KD-43X8307C
  • KD-43X8308C
  • KD-43X8309C
  • KD-55X8005C
  • KD-49X8005C
  • KD-65S8505C
  • KD-55S8505C
  • KD-65S8005C
  • KD-55S8005C
suc6 ermee,
73's
Sabas-kd65x9005c
Member
Ik heb gisteren de update via gedownload en via USB geinstalleerd, dat ging weer probleemloos maar koste zeker 45 minuten.
Ik ben erg benieuwd naar de volgende functionaliteiten:
-Bluetooth audio (A2DP) staat nog niet duidelijk vermeld of dit ook van toepassing is.
Ik ga er vanuit van wel omdat dit de Nougat update is. Zodra mijn nieuwe bluetooth koptelefoon binnen is zal ik het gaan proberen.
-Modus Picture-in-Picture (Beeld in beeld)
Ik ben druk aan het zoeken geweest maar heb nog niet kunnen ontdekken hoe dit werkt.
Iemand een idee?
Tekst bij de update
We kunnen u meedelen dat er op 14 maart 2018 een nieuwe firmware-update (5.381) rechtstreeks op uw tv beschikbaar komt. Deze wordt geleidelijk geïmplementeerd in de lente.
Deze firmware introduceert Android 7.0 Nougat en nieuwe functies, verbetert de prestaties van de tv en verbetert de bestaande functionaliteiten:
  • Modus Picture-in-Picture (Beeld in beeld)
  • Hybrid Log-Gamma (HLG) HDR-inhoud voor USB, DLNA en satelliet-tv*
  • Google Cast 4K-inhoud via Chromecast ingebouwd**
  • Functionaliteit voor zoeken via spraak in de webbrowser
  • En meer…
RoosSBNL
Community Team
Hi Sebas,
Ik heb hier wel een idee over =).
Picture- in-Picture werkt helaas alleen bij analoge zenders. Natuurlijk onhandig, want dan heb je er veel minder aan.
Groeten,
Roos
Sabas-kd65x9005c
Member
Ha Roos,
Bedankt voor je antwoord.
Ik snap nu waarom ik bij het kijken naar digitale HD zenders geen pip optie krijg in het action menu.
Kan je me ook vertellen of de Bluetooth audio nu ook beschikbaar is op de 2015 modellen met Nougat?
Vinc_E
Expert
Dat zou wel moeten ja. Hetzelfde protocol voor bluetooth is beschikbaar in Nougat.
Sabas-kd65x9005c
Member
Helaas,
De KD-65X9005C ondersteund geen Bluetooth audio. Ook niet na de update naar Android Nougat.
Had het ook kunnen weten via de Sony website zie Alleen 2017 modellen
Dan maat eventueel terug naar een Bluetooth transmitter zoals bijvoorbeeld deze
Een en ander als terugkoppeling voor degenen die nieuwsgierig zijn of de Bluetooth audio functionaliteit beschikbaar komt voor hun Android tv.
Bluetooth audio is enkel beschikbaar na de Nougat update voor de volgende modellen:
Applicable TV models
Bluetooth headphones can only be used with the following models after OS update. Please make sure that your model is in the list.
  • KD-**XE9405
  • KD-**XE9305
  • KD-**XE9005
  • KD-**XE8596
  • KD-**XE8599
  • KD-**XE8588
  • KD-**XE8577
  • KD-**XE8505
  • KD-**X9400E
  • KD-**X9300E
  • KD-**X9000E
  • KD-**X8566E
  • KD-**X8500E
  • KD-**A1
SteffH
Explorer
Ik gebruik een KPN HD-tv ontvanger die via HDMI-1 is aangesloten op mijn KD-55XD8505.
Na de update heb ik problemen met de weergave. Het beeld schokt en staat regelmatig stil (bevroren).
De storing is het ergst als er gekeken wordt via een kanaal met een hoge bitrate. Doordat ik een glasvezel-aansluiting heb kan ik een aantal zenders met verschillende bitrates bekijken:
  • Standaard met lage bitrate.
  • HD met hogere bitrate
  • Glas-HD met nog iets hogere bitrate.
Het bekijken van de Glas-HD kanalen is (bijna) niet meer mogelijk.
Zijn er meer gebruikers die hier last van hebben?
Alvast bedankt voor je reactie.
Hennie.
Gokhan1984
Explorer
Na de upgrade lijkt het alsof ik problemen heb met de audio. Ook ik kijk naar tv via een kastje (HDMI) en merk dat de audio bij sommige kanalen later (na 3- sec.) begint met afspelen, zowel bij de tv speakers als  bij mijn soundbar. dus dan heb ik eerst beeld en later hoor ik de audio.
bij het ene kanaal heb ik er wel last van en bij het andere kanaal weer niet.
jjvdsluis
Member
Hoi,
ik zou adviseren om eerst de router waarop de STB zit aangesloten te herstarten en/of de STB eens een keer helemaal van de stroom te halen. Het stotteren van beeld/geluid is meestal geen oorzaak die ligt bij een TV.
