Hi - I’ve got a XH-91 and I’m not able to get Alexa to work.
I cannot see the app in the google store, and when I use tv work with Alexa app I get this message
‘Amazon Alexa. Service will be available in future of this country’ [sic]. I understand there are country restrictions in place and have looked at the location service . It was set to use WiFi to estimate location. I’m using a sky broadband router which has Europe set as its region ( and this cannot be changed).
if I unselect the WiFi option I do not have any other method of setting location.
help please
n
Hi Nicks1964,
Please check-out the following article on how to set-up Alexa with your TV:
https://community.sony.co.uk/t5/how-tos-faqs-tvs-home-cinema/have-you-seen-the-tv-remote/ba-p/371131...
Many thanks Peter for the link. The problem I have though is step one in the video, I cannot install the Alexa app from the google store as my tv does not think it’s in the uk. It’s the tv’s location I need to correct
thanks
All ok now thanks
Hi Nick just read your post and it looks like I'm having the same issue.
How did you solve it.
