KD 49xh9505
TPM1176
New
KD 49xh9505
Purchased Sony and set up in the normal way. I have Sky q and its linked by sky mini and HDMI into relevant port. It works well for several hours 4 + and then with any noticeable issue the screen goes blank, see image below.
After 5 minutes of the (static pixels) it then goes black and then picture returns. I have reset numerous times but the same happens again.
Any suggestions or is the unit defective?image of screen .jpgimage of screen .jpg
Tags (2)
1 REPLY 1
profile.country.DE.title
Peter_S.
Genius
Does the input of the TV change or is it still the same input.
If it's the same input then I would assume that sky box has an issue.
But could be a cable quality issue as well.
