- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Can anyone tell me which tv to go for that is equivalent to the Sony KDL-43W807C 43 inch Smart 3D Full HD TV please? as mine has now packed up though had it since 2016?
Thanks Jules
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you again for your help with this. I presume can set it to automatic updates?
Could I ask when I first set up the TV I did this with google, was that the right thing to do as my previous sony tv was android? Thanks Jules
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes you can set the TV to automatically check for updates.
Press the Setting button on your remote control.
Scroll left to Settings on the onscreen menu.
Scroll down to About, click on System Software Update and switch on Automatically check for update.
Also under About if you scroll down further you can see which Android TV OS version your TV is running.
Android TV was renamed as Google TV (Android is a Google created platform) a couple of years ago,
that's all.
- « Previous
- 1
- 2
- Next »
