I have had my Bravia KD 55 XE 7096 for about six months and it has been connecting without fault to my wi-fi/server.
Then all of a sudden two days ago no connection!
I have tried re-installing the wi-fi via settings, but each time I get:
Connection result:
TV WiFi Found
Local Access Failed
Access internet Failed
I have gone as far as doing a factory reset, but have the same results.
I should add that the access to the wi-fi from other devices is working perfectly with the normal password.
For information the software has been set on automatic up-date, and the latest version is: v8.673-1000-1.280-0000
Any help or advice would be appreciated, or is this a waranty issue
Hi there,
That sounds really frustrating.
Can you tried resetting your Router and let me know how you get on?
Best wishes,
Sean Mc
