TV KD-49X9005 turns off then on immediately at the same time every night (19:40). I have looked into timers, nothing there.
Sounds very strange.
All I can suggest is:
1/ Disconnect the mains for an hour or so.
2/ Now power up and switch on. Wait a couple of minutes.
3/ Now try a 'soft' reset, usually done by holding the remotes power button for a few seconds.
Now test it.
Is there any possibility your mains is dropping out randomly? You would think this would be noticeable in other ways though.
If it is still faulty then I would suggest trying again with no external USB or HDMi leads connected.
Final thing to try would be a full factory reset.
It all sounds very strange tbh. Good luck.
Just a thought, but wireless routers usually renew the DHCP lease every 24 hours, is it possible that that's what's happening? Probably not, but all I could think of.
Hi @inessex, have you tried disabling interactive application by following the steps here: [HOME] → [Settings] → [Watching TV] → [Channels] →[Channel Setup] → [Digital setup] → [Interactive Application Setup] → [Interactive Application] → [OFF], after that turn off [Update Guide in standby] by following the steps here: [HOME] → [Settings] → [Watching TV] → [Channels] → [Channel Setup] → [Digital Setup] → [Guide setup] → [Update Guide in standby] → [OFF]
Try to Wifi instead of LAN and test the performance. I hope this helps
