- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
TV Stands.
How would I fix a Sony Bravia KDL-43W805C TV to a normal TV stand?
Due to the back four screw holes not been the same level I can't see how it would fix safley.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Welcome to the community.
The information you need is here
Let us know how you get on.
Best wishes,
M
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for the reply but by the four screw fittings I was meaning one of these type of stands.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Duncan_Macleod wrote:Thank you for the reply but by the four screw fittings I was meaning one of these type of stands.
Hi @Duncan_Macleod Did you work it out? You simply use the standard VESA holes on the back of your TV. Quote from your suggested stand TV COMPATIBILITY -- Fit for 32 to 65 inch TVs ,VESA patterns 100x100/200x100/200x200/300x200/300x300/400x200/400x300/400x400/600x400
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The issue is the bottom 2 screw holes are not at the same level as the top two, so when I look down from the top the top two are closer to the screen than the bottom to due the raised bit for all the connectors, and all video seems to pick the easiest TV to set up.
