Hello, everyone! I struggle recently with this feature and I am not sure if it is available as mentioned in several Sony Android Tv documentations. I am trying to project Windows 10 PC to the specified Android Tv and when I press Inputs button there is no Screen Mirroring option, there is no such application installed and I can't find it in Google Play Store. Do I want too much, I know about the alternatives - there is AirPlay installed, but I do not have payed AirParrot account and I find it disturbing to actually need anything from Apple while having Android Tv. Not to mention that there are definitely connectivity issues when I try to connect it automatically from Wi-Fi Direct menu. What options do I have?
Best regards!
Miracast is not supported anymore, you can still use google cast that is quite easy on android device but is possible using chrome also on a windows pc
My preferred option is a HDMI cable from the PC to the TV.
Surely your TV has Chromecast built in? Settings/Network & Accessories/GoogleCast. Maybe the ScreenMirroring Source option appears only after first use? Is your TV discovered by casting apps on other android devices?
Hello! Chrome cast works great, I tried it, but I needed to have things outside Google Chrome, like other players and applications, just the way AirPlay and ApowerMirror both work great and I see all content from PC. At least you gave me clarity, I will need either one of these applications or will use HDMI. Thanks for the information and the replies, everyone!
Found "Cast desktop" and the quality is great, thank you very much for this!!
One plus with the HDMI cable option is that you can control the PC from the TV sofa with a RF mouse (or a RF remote or RF keyboard) with the RF receiver in a USB port of the PC. From my RF mouse to the RF receiver it is about 3-4 meters and in between there is my body and a wall to pass. Works fine!
