Just unboxed and set up my new Sony bravia tv to find every thing looks fine except when I go into the program guide I cant go backwards to select a program that was on last week. had a look in google and other people have had a similar problem and recommended I did a factory reset and disconnect the set from the mains for a while but nothing has resolved it. Hopefully some one on here has a fix for me.
Where did you read that your non-android tv has such a feature?
Sorry my TV is a smart one and does have this feature have I put my question in the wrong listing.
Apart form the wrong section, AFAIK there is no freeview certification for sony product and only on Android based tv there is youview for catchup guide and services... maybe some UK user can tell you more
This is a Uk model and does have freeview certification Youview is not available any more on UK models.
