Hi
I'm trying to find my TV Mac address on my Sony KD43X8309C and can't find it anywhere.
Anyone know how to find this?
Thanks.
Hi
It is:
Home - Help - TV information (View network status) - MAC address
Wired MAC is different than wireless.
Thanks.
On a KD43X8307 so perhaps the same, it can be found under Network Settings. In my case selectng the wired option as that is what I use displays the IP and MAC address.
Mick
@MiCal1967 wrote:Hi
It is:
That's right, selecting the active connection method provides the information, in my case wired. Using the help option rather than Network settings does save having to choose.
