- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
The input/info banner keeps popping up (no option in settings)
Best TV I've ever had. Yet, the input/info banner keeps popping up randomly. I see this is a problem for others as well. The TV is a - SONY-KDL43WF663BU - and there is no option under Channel Settings to turn off the banner (as well as looking everywhere else). The i+ button doesn't do anything at all, when held down or pressed. I connect it to a PC and I've disabled the sound. I've searched for updates and there are none.
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there,
Please try these steps to remove channel info from the screen. Let us know if it helps.
Best wishes,
Ed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, thanks for replying.
I don't have a remote with any of those buttons on. The remote is a - rmt-tx300E - model if that helps.
It seems that quite a few people have the same problem. I think it is being passed over to the technical team.
Thanks,
