x
profile.country.GB.title
Zebanet
New
Tekstitys hävinnyt
Viikon vanha Sony Bravia KD 55XE8096 tekstitys katosi kaikilta kanavilta?
1 ACCEPTED SOLUTION
Accepted Solutions
Zebanet
New
I did find the reason: after software update text language was changed into english in digitv text settings. I did change it back into finnish and problem solved..
3 REPLIES 3
jumpsuit
Expert
Hi @Zebanet and welcome to the UK forum :slight_smile:
Please try and use English here if you can.
In answer to your question about subtitles disappearing,
are you sure you haven't turned them off accidentally?
Zebanet
New
jumpsuit
Expert
Hi again @Zebanet
Thanks for letting us know :slight_smile:
