Viikon vanha Sony Bravia KD 55XE8096 tekstitys katosi kaikilta kanavilta?
I did find the reason: after software update text language was changed into english in digitv text settings. I did change it back into finnish and problem solved..
Hi @Zebanet and welcome to the UK forum
Please try and use English here if you can.
In answer to your question about subtitles disappearing,
are you sure you haven't turned them off accidentally?
