Hi all,
Usually when I switched on the TV using remote control, it would just turn on.
But now, in the last few days when I power it on, the LED light on TV will lit up with black screen for 4-5 seconds then it will do the full reboot (spinning android logo). This happens every time.
I did the factory reset but the problem persists.
Anyone knows the fix?
Thanks in advanced.
I am actually having an issue very similar to what you are describing. May I ask you to test if you also are facing the following:
Do you loose the picture (black screen) while the sound still goes on in the background?
@dutchicewrote:Do you loose the picture (black screen) while the sound still goes on in the background?
I tested what you asked. I didn't loose anything. It shows both picture and audio.
Oh well, then the two issues are not related. Thanks for testing. Is your issue intermittent or consistant? Maybe it has to do with lets say a USB HDD or USB Device you have hooked up? I'd try to see if disconnecting all cables and devices from the back won't/will make a difference.
@dutchicewrote:Maybe it has to do with lets say a USB HDD or USB Device you have hooked up? I'd try to see if disconnecting all cables and devices from the back won't/will make a difference.
Unplugged everything as you suggested but it doesn't fix the problem...😩
I am having the same issue. Differnet TV 55X8005c.
Going to try reinstalling the firmware.
Well, engineers came in today and they couldn't fix the problem so they had to take it to workshop.. 😞
