Hi, I have two Sony Android TVs (KD-55A1 and KD-49XF8505) where I have set up streaming channels via Live Channel. It worked fine previously using both the TV-guide and also using the "discovery menu" where I could choose both my Terrestrial TV channels and the streaming channels from the menu (I could add these different sources from the settings in this menu). After the Oreo update the streaming channels cannot be found in discovery menu, I cannot add streaming channels to favorites either anymore. Itis possible to access the streaming channels from the TV-guide where its still possible to change between "digital" and "streaming". I did try a factory reset on one of my TVs but the problem is still there.
Not sure what I did but now the streaming channels are selectable for favourites. In the discovery menu the favourites will be visible so problem solved (not sure but it might have been the same on the old version of Android TV, that the only way to access streaming channels is through favourites in discovery menu).
Hi there,
I would recommend getting in touch with the support team for further assistance here.
Best wishes,
Sean Mc
