Hello,
my problem is that after turn on this TV screen is shaking and flickering for a while. After few minutes everything is ok. Problem persist in TV menu with unpluged all signal cables.
I tried restart, factory reset, different screen settings and not helped.
Here is my problem catched on video:
Did anybody solved similar problem?
Hi there,
If you have tried a reset and are still experiencing these issues with your TV, then it might be best to get in touch with the support team for further help here.
Best wishes,
Sean Mc
