Hi there,
Welcome to the community.
We'll check this and get back to you when we can. Maybe some of our members will have some tips to share in the meantime.
Best wishes,
Ed
Hi Leemonjazz,
That seems really strange. if you disconnect the box, does the same thing happen?
Cheers,
The_Black_Rose
Hi Leemonjazz,
Just to eliminate any HDMI CEC glitches, try either disabling Bravia Sync from the external inputs menu on the TV or disconnect the Virgin box's HDMI cable from the back of the TV, test it, and let us know the outcome.
All the best,
Tenneen9000
