Sony tv model is kd55x75wl why is volume 40 and Sony soundbar ht-zf9 why is volume 20
If you have accepted your own question as the solution, then why are you still asking it?
@andy1970spurs wrote:Sony tv and Sony soundbar different volume why
Hi @andy1970spurs I assume that you mean different volume level displays. Maybe because each has its own amplifier, with two separate amplifiers you will get two different volume level displays and scales.
@andy1970spurs it's always better to mention the model numbers, also do mean the scale or that they do sound different?
The Sony tv is 40 and the Sony soundbar is 20 why
