TV model SONY KD-55XH9096
After last two soft updates. The factory function Airplay is not working properly (after a while it starts to squeak). What can you suggest?
Practically everything has been tested: factory reset and the like, the last update also don't repaired my problem
Also SONY support in Lithuania and Baltic states won't help because technical the TV is good
Hey @aleksandrsmirnof, I've been facing the same issue! Accept the privacy policy as a workaround by pressing Help - Status & Diagnostics and open Privacy setting - then agree to the Sony Smart TV services’ and press Proceed. Then, press the Input button on the remote and select AirPlay from the input selection. You can also try a forced reset by holding the power button for 10 secs.
Hope that works!
