KD 49XG9005 -Sound dissapears sometimes when switching back over from internet- tv
( seems to be only since last update)
Have to re-start android to cure the problem ( just switching off does not solve it)
Hey,
Maybe try to clear the cache and data for the TV
-Go to [Settings] - [Device Preferences] - [Storage] - [Internal shared storage] - [Cached data] - then click [OK] to clear it.
Also do you have any audio device connected? or this happens on the TV speakers?
Cheers.
@petemech, have you made sure that the , latest software version is installed? You can also try resetting the sound settings by pressing (Settings - Display & Sound - Sound - Reset)
Hi Piscie,
Sorry for delay in replying - but i wanted to make sure your suggestion worked OK
AND it did : ) So as it was intermittent, i left it for a fortnight to make sure.
So now i can enjoy watching tv & internet based progs again !
Many thx ( much appreciated)
Forgot to add -It was re-setting the sound that did the Job : )
