I have a Bravia KD55X8005c and watch movies from a USB external drive plugged into the TV. I use the default Video app that comes with the TV. The movies on my external USB drive are sorted into folders, but in the Video app on the TV there does not seem to be a way to sort folders and I have to scroll through pages of folder icons to get to the one I want to watch.
I have read on some forums that the Options button would allow the View to be changed, but my remote does not have an Options button.
Hi there
It doesnt appear that you can sort videos via folders in this years Android TVs using the Video app.
However, i would suggest trying Kodi - as it has many more functions at this time.
