I recently bought Sony 43x8305C and mostly happy with my purchase so far.
One nagging issue I found that when the TV is on standby, I could NOT see the google cast icon or the Sony DLNA renderer from my smartphone.
Both Google cast and DLNA renderer (network) comes back online when the TV is switched on. Is anyone of you facing the same issue?
It would be great if someone can tell me how to resolve this.
Regards
rdrpbu
Hi there
Im not too sure on what the actual issue is, simply because what you have described appears to be normal operations.
Upon turning the TV off into Standby, the TV reduces its power use by shutting off services it does not need. The TV does not need certain network services such as wifi-direct or whatever google uses for its cast functions when in standby.
