Hi Everyone
Could anyone please tell me what the constant orange light is on the front panel of my Sony XR AJ 90 and how to turn it off ? The light remains on even when the TV is switched off. Thank you
Thank you SO MUCH for your prompt and very helpful reply Marino👍🏻👍🏻👍🏻
How the LEDs light up
https://helpguide.sony.net/tv/iaep1/v1/en/01-03_06.html
You want to disable the LED so that it does not light up or blink.
