x
Sony TV external HDD
profile.country.GB.title
ManosPer
Explorer
Hi. I am an owner of sony KDL43W808C.
Today I bought an external HDD "Verbatim TV Hard Drive Rec & Play" 1TB formatted NTFS.
The reason is because I want to see movies which I downloaded to my pc, in my TV. Now my questions are the following.
1.I can't create any folder from my usingtv  apps like es explorer or x-plore. I haven't the permission! How can I fix that.
2.Can I use my external HDD for both recording TV and watching movies as usb?
Thank you and sorry for my English.
4 REPLIES 4
ManosPer
Explorer
Also is there any way to send downloaded movies from my mobile to external HDD?
Thank you!
Mick_D
Moderator
Hi @ManosPer
It's possible you haven't registered the drive yet, or there is some problem with registration. This Support article guides you through the process.
Best wishes
Mick
ManosPer
Explorer
I try to register the drive but again I can't write on it and also it shows that its capacity is 256gb and not 1tb.
ManosPer
Explorer
Could someone plz tell me the correct file system to format my disk. I just want to see some movies which transferred to my HDD. And also I want to be able to insert or delete some of them using my android TV and my Windows pc too. Thank you.
