I just got a Sony android tv.
All updates are current (two and a half hours if you're interested) but the Sony Select app is in the wrong language.
I'm not sure which language it is, Cyrillic alphabet though.
There is one Irish app, one UK app, a couple of German ones and some Asian ones.
Any ideas on how to fix this?
I'm only interested in the Sony Select app because it's the only way to add certain catch-up apps.
In case it's relevant, the subtitles keep turning on on all tv channels (yes, I've tried every option to turn them off).
Hi Feroluce
Sorry to hear this is not solved
Best solution is what Quinnicus said.
Or wait until next firmware release, maintain Location ON, check your ISP modem domain to be the default used from its services and perform the Firmware Update with the online option. Not USB option.
Firmware will be from scratch and possibly will solve your issue.
Can't think of someting else...
