Hi all,
My Sony Android TV (kdl43w805c) has suddenly stop starting. I can see the logo sony appearing on the TV and white led starting blinking smoothly but then the TV stops and start again forever. I have seen previous mentions of this problem on the forum but it does not seem that anyone has found a solution.
So far I have tried the soft and hard reset. I even tried to force the hard reset using the buttons located on the back of the TV. It did not do anything as the TV keeps starting and stopping all over again.
Has anyone found a solution to this problem?
Many thanks for your help!
Hi there
This is becoming all too common now
Please see this thread for suggestions - but its more than likely that your TV will need to be repaired.
https://community.sony.co.uk/t5/android-tv/android-tv-bootloop/td-p/2282949
Hi there
For reference though - is it something you may have done or changed on the TV (i.e. A setting or installation of an App). Or was you updating the firmware.
I would like to see if there is a common cause on this. Updating the firmware has been known to cause a 'bootloop' from time to time - Sony claim they have fixed this issue - the firmware update causing it. But it appears there are other ways this occurs too.
Just curious if you know what happened just before this occured.
Thanks
Thanks for your help Quinnicus!
Interestingly, my case seems to be a bit different. My TV was still working properly last night as I was playing a game on my PS4. Today when I got back home, I switched on the TV and the screen was yellowish. So, I decided to soft reset the TV hoping the image would be normal again (I pressed the power button on the remote control for 5 seconds). Then, the TV restarted but did not show the android animation. Instead it stopped and started again and again and again... 😞
You're Welcome
Interesting about the "yellowish" screen. Thanks for that extra info as im going to start collating this, to see if there is a common cause or not - but ultimately to pass to Sony for them to investigate this thoroughly.
Cheer
I have contacted SONY repair services. I'll let you know what happens next. My guess is that there is a bug in the Sony's android modified version that runs on their TV. Android cannot boot for whatever reason, that's why the TV restarts again when it failed to load any operating system. I wonder if they charge for fixing this if the TV is not warranted anymore (Mine is still warrantied tough).
Hi all,
Just a quick feedback on the issue.
I have contacted the retailer that sold me the TV. They have sent some TV repair specialists. They took the TV to their workshop. They tole me that they needed to use the SONY TV repair tools and it would take at least 2 hours. I guess they are installing a fresh SONY android system on my TV.
Thanks again for your help Quinnicus!
Hi guys,
I have just got back my TV this morning. The repair that should have taken a day took two weeks. The invoice says that they had to change the main PCB.
If you have the same problem as I had, it seems that there nothing you can't do except from calling customer services.
I hope this helps.
Hi @Dongy_
Thank you replying back - yes, unfortunately when this issue happens, its is the mainboard that needs replacing.
Hi all,
Same problem here. After a complete factory reset the TV (50W808C) does not start.
After plug in AC appears Sony logo, then the animated balls from android and then restart again with Sony Logo.
After aprox 10 min, the Sony logo appears frozen and thats all.
I have tried "forced factory reset". Power + volume down.. the led turn green, restarts two times and instead of starting Android, starts again with the boot loop. it´s really frustrating.
My TV was running Android 7.0 recently (2 weeks ago) installed by USB after crashing Android TV on Android 5.0 (same boot loop but the TV was crashing when "initialitating app XXX of xXX"). Finally i get this solved by installing Android 7.0 from a USB stick. After this, the TV has been working for 2 weeks (very slow and finally some applications like play store or youtube didn´t work, so i decided making the complete factory reset)
I have tried installing again the latest firmware (same as installed) but during the instalation the led turns blue and restart again..(after reading information from internet, i suppose we can only upgrade the firmware with a new version, not previous or equal).
So acc. to all post from other forums it seems like the only thing that we can do is to send the TV to a repair center (or throw it TV directly to the trash).
In my case, i bought the TV on Jun 2015 so the warranty has expired.
I can not understand how Sony can allow that a huge quantity of sold Android TVs has been crashed.
Sony has died...
Now, i am trying to get information about replacing the mainboard by myself ( cost around 50 €) but i am not sure if really it´s possible without extra "software" from Sony Support. It´s annoying. I suppose that is not plug and play, maybe we have to make something special with Emmc or who knows.
if you have any suggestions please....
