Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi Tango1376
Can you please respond back with your model number.
i got this problem to i need help
please private message mea solution
... thanks
Seems to be the same problem with KDL-50W808C. Please suggest. Thanks!
Hi, send me a solution for a crashing issue with KDL-42W705b please. Thank you ^^
Hello Quinnicus,
I have the same problem in Spain in a W80 C model.
Please, could you provide me the solution?
Thank you very much!
@MrCapullo - ive sent you a message with a fix, let me know how it goes
@leet.Smithy - this fix is only for 2015 android TVs. Your model is a 2014 non-android. Can you describe what is happening?
It's an inbuilt mediaplayer on Bravia. It crashes everytime when I try to watch any movies from DLNA. Every 10-20 min my stream freezes and TV won't work on properly without unplugging its power cord and plugging it back in. It started happening after downloading new software.
