Anybody else have the same issue that you can not change rgb range after update 7.0?
I can not find it in the menues anymore.annoying
Hi @enurtrebla,
This setting is only visible when the TV is on the HDMI 1 to 4 inputs. You can find it under:
ACTION MENU > PICTURE ADJUSTMENTS > ADVANCED > VIDEO OPTIONS > HDMI VIDEO RANGE
Take a look and post back more detail on the input and device you are using that requires a change, since the setting does automatically the detection for you and changes it accordingly.
Thanks for reply:-)
i tried to go to picture advansed but no videooptions and rgb range.
i just want the posibility to change my nintendo switch to limited or full if i want to like before.
it would not be a problem if it was on auto at defalt but its not,because when i change my Nswitch settings from full to limited i should look about the same.but i does not.
i think this setting was under display before
The setting you are looking for is shown at the very end of this video:
thanks.
But there is no video options in my advanced menu.it used be in display setting before on my tv but can not find it any more.my menu look a little different than x900.
