Hi all,
As in the title, I'm gonna get this unit for my PS4 pro, but keep reading is has bad input lag, Its my dream set up though so I was wondering can the lag be reduced with future firmware updates, is that even possible? Should I wait for a different TV instead?
Thanks so much
I tried email sony but got cut and paste answer that made no sense at all
Sorry but I don't think so, Input Lag depends by the hardware of LCD Panel, beyond a minimum value I think is not possible to go.
Manolo
Thanks a million Marino, you've been very helpful. I might just wait till 2017 bravias instead, if i can be that patient
Manolo
