Hi All
Just got a new 2015 Bravia and love the picture.
One issue that is really bugging me however - I have a home network with several Media Servers on it. This TV can see the Media Servers (Google Video etc) when the TV is connected to the network by WiFi However when I have the Network cable plugged in for faster performance (same network) the Media Servers are no longer visible. I have checked all the usual suspects and other devices connected to the same network can pick up the Media Servers with no problems.
Anyone else experiencing the same problem? or better still have a solution!
I'm am having a similar issue but at the same time I can't use YouTube google play cast to the TV etc? Is this the same? I tried wireless though and had the same issues...I'm the 55x85c new 4k range,
I am having the same issue. Works perfectly on Wifi, but if I use a ethernet cable plugged into my BT Home Hub 5 router, it cannot see my Western Digital myCloud network hard drive.
Anyone found a solution?
I'm having the exact same problem. NAS is found fine using wifi but not with a cable.. Yet when cable is connected I can use internet, youtube etc, it just wont find DNLA NAS server... Ive tried switching the WiFi on and off etc.. did you get a fix for this??? Thanks
reboot your tv and router, should be ok after that.
Tried this now several times. The TV will simply not run my QNAP NAS over a wired network. Only via WiFi. Poor!! But thanks for the suggestion
