- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony KD-55XH9005 Restarting
I've been having random restarts with my XH900, but its been very bad since the latest firmware update that was released in June of 2022. You can tell its about to do it as the sound starts stuttering and makes a buzzing noise then the TV restarts by its-self, and shows the Sony and Android boot logo. I've done a factory reset on the unit and the issues remain. Has anyone got any recommendations about this issue or are Sony aware of the problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @StuTheStig
I’m afraid that Sony will only be aware of your problem, if you contact Sony Support for your country or region. If it was a general problem, then we would expect a lot of noise about the problem in the community.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same problem here, this firmware version needs an update, i read a lot of people have this problem with this version.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did that happen after updating this version: v6.1772? Cause this is supposed to be resolved. But you can also try these: Go to [Home - Settings - Network - Home Network - IP Control - Simple Ip Control] and set it to ON, and go to [Home - Settings - Watching TV - External Inputs - Advanced settings - RS232C control] and set it to OFF. Hope that helps.
